Valve to piston clearance ?
Big Block A body Tech
  1. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    10:53 AM
    First my motor is 470 stroked 400 with stealth heads and a 586 solid roller comp. cam and 11.00 cr. I put some playdo in the valve reliefs to check clearance and the the intake side was about .300 and exh. was about .400 with 82 cc heads. Does this sound right, if not what is wrong??? Rockers are Hughs bushed with roller tips.
  2. DJVCUDA
    DJVCUDA Well-Known Member
    1,083
    7
    May 26, 2004
    Local Time:
    4:53 PM
    without knowing alot more information like piston , deck height, gasket thickness and so on it;s not easy to say, but it sounds like you have a friggin mile... you need to be at lease .090 and you got that!
  3. IQ52
    IQ52 Well-Known Member
    2,488
    1902
    Jul 30, 2011
    Idaho
    Local Time:
    9:53 AM
    Did you rotate the engine over slowly for a few revolutions, with the cam installed and timed?
  4. 67Dart273
    67Dart273 FABO Gold Member FABO Gold Member
    46,659
    14555
    Oct 14, 2010
    Idaho
    Local Time:
    8:53 AM
    X2. What sort of procedure did you use for these measurements? You can not for example, check V/P clearance at TDC. There is a point as the piston comes up, over center, and back down, that valve clearance is actually LESS than at TDC
  5. bOb shingler
    bOb shingler Well-Known Member
    3,250
    163
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    11:53 AM
    this has to be done as was said in answers 3&4. you're looking for .100" on exhaust and .090" on the intake to be on the safe side.
  6. challenger57
    challenger57 cuda57
    207
    15
    Sep 21, 2007
    york, pa.
    Local Time:
    10:53 AM
    Yes hand cranked it several times. Took it apart and redid it several times just to be sure and came out the same.
  7. ramcharger
    ramcharger Dismember
    14,143
    121
    Nov 15, 2005
    Lakewood, Colorado
    Local Time:
    9:53 AM
    Keep in mind that if you are using hydraulic lifters, the springs and clay will push the lifter plungers down to the bottom of the lifter bore giving you a false reading. The correct way to do this is with a light checking spring and a dial indicator on the valve retainer.
  8. DJVCUDA
    1,083
    7
    May 26, 2004
    Local Time:
    4:53 PM
    he said it was a solid roller fyi
  9. moper
    moper FABO Gold Member FABO Gold Member
    15,849
    1965
    Dec 27, 2004
    eastern CT
    Local Time:
    4:53 PM
    So long as you rotated it a few times it sounds fine. That clearance depends on the piston, the deck height, the cam, the sizes of the valves, the head, and the head gasket. So there's not much for a specific number to shoot for... Just don't let them get too tight as Bob said.
  10. greymouser7
    greymouser7 Vagrant Vagabond “Veni Vidi Vici” FABO Gold Member
    3,360
    2650
    Apr 17, 2010
    78002 down the road from Atascosa, Texas
    Local Time:
    10:53 AM
    how much stretch is there in the valve train when it heats up?
    When Jim/IQ52 competed in the engine masters Mopar muscle challenge, this other guy with a 361 had his valve hit his 361 piston and blow up the motor. I assume that he did a valve to piston check...? is this limit pushed with these kind of builds?
  11. IQ52
    2,488
    1902
    Jul 30, 2011
    Idaho
    Local Time:
    9:53 AM
    The 361. Somebody there just made a big mistake, all eight exhaust valves were hitting the top of the cylinder walls/deck....small bore/big exhaust valve. They said they had checked all the clearances. #2 exhaust valve was the first to break and shut the engine down. You could look into the exhaust port and see the camshaft.
    Our 451 engine, two years before, had .052" piston to valve clearance on the intake and .068" clearance on the exhaust. We had no problem spinning it to 7600 rpm, but, I'd like to think that was because we know what we are doing. Its important to be smarter than your cylinder heads.
    • Like Like x 1
    • william
      william Well-Known Member
      175
      11
      Aug 13, 2009
      Ottawa
      Local Time:
      10:53 AM
      If I recall it didn't hit the piston it was clipping the cylinder wall ,the 361 has a small bore at 4.12" compared to a 400 at 4.34
    • ramcharger
      14,143
      121
      Nov 15, 2005
      Lakewood, Colorado
      Local Time:
      9:53 AM
      Please re-read my post. I started with "Keep in mind that IF..." I posted that as a benefit to those that read this thread so they don't make a costly mistake. Having the whole story and complete information is always beneficial.
