694spd
I need to buy a new set of valve springs for my 340. I just looking for a stock replacement set that has spring rates similar to the original factory ones had. Any recommendations?
comp cam 901.....
All listed, Single-Coil with Damper
Mopar Performance #4120249 {Stock 340 Replacement w/.206" Coil-Wire}
#90 lbs. @ 1.68"
#230 lbs. @ 1.27"
Mopar Performance #5249847 {340 XHP}
#103 lbs. @ 1.68"
#260 lbs. @ 1.20"
Compu-Cams #901
#101 lbs. @ 1.65"
#242 lbs. @ 1.25"
Hughes #1110
#120 lbs. @ 1.66"
#280 lbs. @ 1.21"
Edelbrock #5877
#90 lbs. @ 1.65"
#240 lbs. @ 1.25"
Trick-Flow #16901
#101 lbs. @ 1.65
#242 lbs. @ 1.25"
Speed Pro #VS-678
#91 lbs. @ 1.65"
#231 lbs. @ 1.22"
Crower #68305X1
#95 lbs. @ 1.65"
#250 lbs. @ 1.20"
Lunati #73084
#119 lbs. @ 1.75"
#246 lbs. @ 1.25"
Crane #99835
#90 lbs. @ 1.65"
#280 lbs. @ 1.15"
Howards #98412
#120 lbs. @ 1.68"
#295 lbs. @ 1.17"
Schneider #68044
#125 lbs. @ 1.65"
#300 lbs. @ 1.15"
