340sFastback
If you do a valve job metal will be removed from the valve seat making the valve sit deeper in the head and the valve stem will move further out on the spring side. That will improve your geometry.
I would talk to the shop doing the valve job about how even they can make all the valve stems so you don't end up with some valve stems significantly higher then the others.
