MSD Blaster coil - $20
Holley Street Avenger 670 cfm - $200
Carb Spacer $15
Edelbrock Valve Covers - $15
Various Mopar Logo bolts - $15
Chrome Dipstick - $5
Trans crossmember - $50
NEW 90* oil filter adapter - $75
LA Tube and Peen P4120603 - $60
LA Lifter Bore Burnisher .906" - $50
Oil Pressure Relief Spring - $5
MSD 6 AL Box $175. (((( sold ))))
Accel 8.8 Ferro-spiral race spark plug wires $10 (((( sold ))))
Edelbrock Performer RPM intake $100 (((( sold ))))
Flow Kooler water pump $50 (((( sold ))))
Milodon Windage tray $50 (((( sold ))))
Milodon Windage tray stud kit $50 (((( sold ))))
Alternator $50 (((( sold ))))
Chrome water neck. $10 (((( sold ))))
Timing chain tensioner $25 (((( sold ))))
Sway Bar $65 (((( Pending ))))
Intake Bolt set 12 point $10 (((( sold ))))
LA mopar distributor bushing $5 (((( sold ))))
Cloyes timing chain $40 (((( sold ))))
Dist. Bushing installer. $75 (((( sold ))))
Clutch/ brake pedal assem. $200 (((( Pending ))))
Mini-Starter. $40 (((( sold ))))
MSD Spark Plug Wire Set $15 (((( sold ))))
LA Crank and Water Pump Pulley $50 (((( Pending ))))
I’ll be at Fall Fling in Van Nuys, CA on Oct. 26. I would deliver the parts there no charge. I’ll also deliver anywhere in San Diego county for no charge if it’s more than one item. Other than that shipping will be from 92118 if you want
John
Carb Spacer $15
John
