Gabriel Larson
I have been having a problem with my 1970 dart veering to the right after a crash that broke my lower RF ball joint. I clipped a ditch and ripped out lower ball joint and did dent the K frame. I have to this date put on new lower ball joints, tie rods, pitman arm, idler arm. brand new Qa1 tubular upper control arms. it has 10 inch front drums that I haven't rebuilt yet but pads look brand new and all the springs have color. The wheel bearing look to be in okay shape and I repacked them. I have had 3 alignments two at different les swabs and the third one I did with a teacher in my autobody class were I put on the new UCA. we got the measurements correct to the specification of QA1 sheet and nothing changed. When driving and letting go of the steering wheel it will self steer to the 2 clock pistons and when holding it straight and stomping on the brakes it will pull hard to the right. I do know the LCA bushing needs replacement along with the strut rod. I made sure that the power steering control valve was lined up by jacking up the car and turning it on the wheel didn't move at all and then I took power steering belt off and drove it still pulled to the right. for while now I have been blaming different parts like Power steering and brakes but I have come to the conclusion I do not know what is wrong I need help.
