Vent window channel seal source?
fnabody
Would anyone know of a source for a replacement vent window channel seal? This is for my 1970 Swinger 340.
Are you referring to the piece of chromed pot metal that the actual vent window glass sits in? If so, that is glass setting tape. Otherwise, the actual vent window gasket is available as a reproduction piece from Metro Rubber products. The mylar glass channel run for the the front door glass that slides up with the glass inside the stainless trim is available as a reproduction piece. Just need to know exactly which piece your looking for??
I'm referring to the pot metal piece that the vent window glass sets in.
Laysons has all of that stuff too! You can contact them thru the site here thru member "Rick@Laysons"
