investigator
any great ideas out there about venting under hood Heat don't mind cutting the hood a little
thank you I will check that out98 Grand Cherokee with 5.9 had hood vents located near the front of the hood, just behind the radiator. This is a high vacuum area when the vehicle is moving to help draw air out.
Don't know just saw some post. Glad to hear it thanksThe problem with these ideas is "I like my cowl vents." INTO the interior, that is. If you vent the hood, seems like the passenger compartment will suffer. If you have a good radiator and fan, why does it NEED venting?
