Hi guys I got the Moroso venturi PCV pipe and it has a V notch in it . When installed it looks like it will be right in the exhaust flow. does that sound right? Also the directions say to put it in the header collector. Has anyone put it in the header flange a little more down stream? The velocity will be a little faster but more important easier to weld Thanks for all your help guys
