dkbug, here's a cloyes on rock auto
http://www.rockauto.com/catalog/moreinfo.php?pk=6092&cc=1435028&jnid=519&jpid=3
With that being said, and not to step on toes, but I personally would look at a complete set, the reasoning being there are different pitches on the teeth due to manufacturers having different roller diameters on the chains. Rock auto lists two double roller chains made by cloyes, one is a 1/4" roller with the other being 3/8. My point being if you mix and match and things are not the same it will create some issues. The p/n on the chains are 9146 and 9134. This is just a quick example of differences.
I looked this up under a 69 coronet 440.
