racingsnake440
- Joined
- Aug 29, 2005
- Messages
- 337
- Reaction score
- 37
I'm looking to get 300-350hp as cheaply as possible. How close do you think I would get with the following?
stock short block
308 heads - stock apart from port matching, minor clean up and milling to increase compression to about 9.5:1
cam - open to suggestions, i like the idea of running a solid cam and have 273 adjustable rockers (are they worth using even if i run hydraulic?) it's going in a 4 speed car with no power accessories so i don't mind a lumpy idle but don't want to kill mileage - would like at least 15mpg
Weiand dual plane manifold
Carter Thermoquad or Holley 750 v/s
headers - any preference between tri-ys and 4-1?
2.5" dual exhaust
Any comments would be appreciated
stock short block
2.5" dual exhaust
