[FOR SALE] Very trick SB 727 full race transmission and Turbo Action 8" converter
physixx
Edison, NJ
I have for sale a very trick SB 727 transmission. It’s a full race 727 with very few runs on it. Probably around 20 runs. Pro-Formance Transmissions in Delaware did the freshening in 2017. This trans has the 904 internals in it but uses the 727 case so less reciprocating weight. This trans also uses the 727 input shaft. It’s got a Turbo Action cheetah reverse pattern manual valve body P/N 17156 installed. This also includes a new Allstar performance dipstick tube with the NHRA required locking dipstick P/N 69121 and the MP steel deep pan.
I also have for sale the 727 converter that was used with the trans. It’s a turbo action 8” converter that flashed to 4500 rpm behind a 360/408 stroker engine. It’s also also set up for use with a trans brake and carries P/N 17508XXMSM46. I am also including ARP converter to flexplate bolts. The converter has the same number of runs as the trans. About 20 runs.
I would like to get $1500.00 for both the trans and converter together plus the shipping. Due to the weight and size of this package, truck freight would be used.
Ken
Edison, NJ
Not sure about it being rollerized but I believe it has aftermarket aluminum drums.
