mopardads67
I have a question about harmonic balancers.OK 95 dodge ram magnum 318 heard what sounds like bearing ready to go on either the altornator or idler pully so I pop the hood.Looking around to hear where the noise is coming from I notice that the balancer has a slight wobble which I thought to be odd.I had the trans rebuilt and a new convertor installed about 1 year ago and for the past couple of months the motor has a vibration on cold starts and idle and real bad under hard acceleration.Is it possible for the convertor to transmit vibrations to the balancer or is my balancer bad?Will an LA convertor work on a magnum engine? Any info would be appreciated.Thanks
Mark
I meant to type would an LA balancer work on a magnum
Mark
