oldmopardude
no problem,If you’ve read the entire post, you’ll notice I’ve kept the body shop out of the conversation. He is a great guy, mistakes happen. What I’m trying to do is recover from the loss. If we have to cut paint, then we’ll cut paint . Just set the car on the ground here are some pictures . And thank you for your civil response .View attachment 1715216132
I can Imagine the grief it is causing.That vin has to be on the drip rail unless the quarter has been replaced. The factory was not precise where they put it. It could be up by the window, or down close to the tail light. unfortunately, you have to scrape the glue and paint off to find it. if it is there, the Indentation will be present from underneath.same with the radiator support, I have seen them on the top, on the back,facing the engine,(between the radiator and the support itself) and on the front of the support looking straight towards the engine. my demon has it right smack in the middle of the support.
