vin number locations
ch1ll
Belgium,wi
can anyone post a picture of the location of the vin number on a radiator support of a 1969 dart swinger? need to verify if the car matches the vin on dash. also where is it on the motor?
There is not an 'exact' location on the radiator support. It can be on the top or engine side, from about the center of the car to the battery area.
Engine VIN is on the passenger side of the block, down low.
They hide it under the antifreeze sticker sometimes too on the DS side top of rad support
there should also be one on the left middle trunk lip under the seal, but can normally be seen from under. You might want to verify both as through the years these cars get in accidents and parts get changed.
