[SOLD] Vintage Ansen BB scatter shield and block plate
physixx
Edison, NJ
I have for sale a vintage Ansen scatter shield and block saver plate for the big block engines. It’s an older one but even though it’s stamped meets SFI specs for NHRA and IHRA, it would need to be certified for regular track use. For street applications with occasional passes down the track, it will be fine. Included with this setup is an adapter ring so that any of the Mopar transmissions will fit and will accommodate either of the transmission input shaft collar bearing diameters. I could not see any marks where it was bolted to a block or where the block plate bolted to the shield so this might very well have never been installed. I would like to get $100 plus the shipping for everything. This thing is heavy so shipping might be a bit expensive depending on location.
Ken
Edison, NJ
