1972Swinger
I am looking for a set of vintage traction bars designed for MoPars.
Not interested in "universal" type bars. I need a set that bolt to the bottom of the leaf spring pack and replace the shock plate.
Important! I need a set like those pictured that have the "safety hanger" behind the axle pad mount.
PM if you have a set lying around. May consider those designed for GM or Fords if they are in good condition, or those lacking the rear safety hanger.
Thank you!
(And yes, I know MoPars don't need bars because of the pinion snubber, but I want a set because I have the rear of my car jacked up so high and I like the look of bright yellow bars hanging under the rear axle a lot!)
Thank you!
