[SOLD] Virtually New Magnaflow 12216 mufflers
VOETOM
KC, MO area
Have I got a deal for anyone needing almost new Magnaflow mufflers!
I removed these and installed a set of mufflers that actually muffled a big Chevrolet powered 57 truck. These have about an hour of run time on them. As typically done, the custom fabricator welded the inlet on and welded brackets on to their outlet. I removed the fingerprints from them and squared up the inlet bushing where we cut them off of his system.
These are 14" long, 9" wide and have 2.5" inlets and outlets. They are stainless steel 304 and are typically $102 each from Summit and Jegs and others.
For anyone on here needing them I'll sell them for $100 and split the shipping with you. I am in the KC area at 64086 zip code. The box they are in is 20" by 11" by 10" and it weighs 17 pounds.
Pm sent too .
Max, waiting to hear from 340Sport since he was first to reach out. Hopefully, will later this afternoon.
Tom
yea? the dynomax super turbos always seem to drone for me..
Hi Joe. These long ones do not noticeably drone on typical street HP cars. Also, when mounted with stock hangers or ones that allow no physical connection (metal to metal) between them and the chassis, they tend to be pretty darn smooth and quiet. We have had good luck with them and the offset offset ones, 17749.
Tom
