thanson_mopar
can sombody tell me why you cant put 77 volare disc brakes on a 74 duster?
the 73-76 disc lower balljoints and upper control arms or will drum baljoints and upper control arms work?AdamR said:Some say its a bad idea others say its fine. I have a set for my car. You need 73-76 A body lower balljoints and upper control arm assembly to use them.
thanson_mopar said:the 73-76 disc lower balljoints and upper control arms or will drum baljoints and upper control arms work?
BJS racing said:I had a 73 Duster with Aspen (same difference) brakes on it. I just took the spindles and the brakes. I used the Duster upper and lower joints and it worked fine. As a matter of fact I did the alignment with a tape measure and it never vibrated or had any premature wear on the tires. I drove the crap out of that thing too! Actually I did use the Aspen lower ball joint just because I was too lazy to try to change them.
