shoud it be wired into blue /w tracer ign wire under dash, or run from big hot post at alternator??
I wired one to a keyed source.Direct would get you a drain unless you are using a disconnect switch or something.
It will be on at all times then. I personally want to know what is inside the car because it will show problems if there is a voltage drop.
