Dartnewbie
Former Dart owner
- Joined
- Nov 11, 2008
- Messages
- 407
- Reaction score
- 0
I assume there is no replacement for the early A's voltage limiters that are built into the gas gauge, so I am attempting to build my own. I have made power supplies for electronics before and this is a simple 5vdc supply to the gas and temp gauges. I plan on using 2 voltage regulators, one to step down to 9vdc and from there into a 5vdc to the gauges. This will reduce most of the heat generated from the regulators. The size is less than 1 inch square. It will pick up the main feed from the same wire that feeds the gauges now and connect back into the gas gas at the factory circuit board trace. If it works well enough I may make a production run and offer it as a kit and as a built unit. I am just wondering if any of you early A folks would be interested in having gauges that don't swing back and forth due to the factory limiter either going bad or just being wacky most of the time like mine is. I'll post a pic of the prototype and let you know how it works.
