[FOR SALE] W2 Econo heads big solid roller
SpareParts
wisconsin
Rating - 0%
0   0   0
Listing some more nice small block parts that'll get your A MOVIN!
W2 econo heads, ported, 3 angle valve job, Isky springs good to .600" flat tappet, 11/32 stem stainless steel valves. No sheets but flow was 288cfm @ 600" intake and 218cfm @ 600 ex, heads have only been surfaced .005 and the chamber is 68cc. On a pump gas 323" SBM trapped 131mph at 3300lbs.
Heads come with Mopar Performance 1.5 roller rockers and .120 wall 3/8" Manton push rods ($320 new)
Price on heads with rockers and push rods is $1800 obo
Mopar M1 W2 intake, single plane square flange 4150. Nicely ported, ran very well, matches the heads. Asking $250 obo
Indy 360-3 (? Can't remember the number) oval port intake, very mildly ported, nicely done, 4150 flange, will make good power! Price is $350 obo
Custom ground solid roller cam and correct Isky springs, also have comp roller lifters, all used very shortly. One tie bar on a lifter pair broke, can be replaced for around $100 I believe. Have the right distributor drive shaft for the roller also. Specs are as follows:
Lift with 1.5 ratio 638/630
Lobe lift 425/420
Dur @ .050 258/266
Lobe Centerline 108/116
Lobe Seperation 112
Degree intake lobe to 108
Price on valvetrain parts, $900 obo. Over $1600 new here, only about 3-5 passes on it.
Pm with questions please
Offers are okay fellas. We're cleaning house and getting rid of the go fast LA stuff, check other ads
Heads are sold, M1 is pending payment. All else still available. Pm with questions. Thank you
M1 is sold.
Price drop. I'll take $750 for the valve train, that's giving it away!
Indy intake, $300... that's like 1/3 off new price
Also have W9 heads and intake for sale in another ad, wanna go fast? I can help!
Indy intake sold to a member here
everything else still available and negotiable. Buy some stuff, throw it in your motor, scare your friends next year :D
