SpareParts
Listing some more nice small block parts that'll get your A MOVIN!
W2 econo heads, ported, 3 angle valve job, Isky springs good to .600" flat tappet, 11/32 stem stainless steel valves. No sheets but flow was 288cfm @ 600" intake and 218cfm @ 600 ex, heads have only been surfaced .005 and the chamber is 68cc. On a pump gas 323" SBM trapped 131mph at 3300lbs.
Heads come with Mopar Performance 1.5 roller rockers and .120 wall 3/8" Manton push rods ($320 new)
Price on heads with rockers and push rods is $1800 obo
Mopar M1 W2 intake, single plane square flange 4150. Nicely ported, ran very well, matches the heads. Asking $250 obo
Indy 360-3 (? Can't remember the number) oval port intake, very mildly ported, nicely done, 4150 flange, will make good power! Price is $350 obo
Custom ground solid roller cam and correct Isky springs, also have comp roller lifters, all used very shortly. One tie bar on a lifter pair broke, can be replaced for around $100 I believe. Have the right distributor drive shaft for the roller also. Specs are as follows:
Lift with 1.5 ratio 638/630
Lobe lift 425/420
Dur @ .050 258/266
Lobe Centerline 108/116
Lobe Seperation 112
Degree intake lobe to 108
Price on valvetrain parts, $900 obo. Over $1600 new here, only about 3-5 passes on it.
Pm with questions please
Lobe lift 425/420
Dur @ .050 258/266
Lobe Seperation 112
