SWED67barracuda
Hi Gals n`Pals. Does anyone know where to find parts for W2 cylinderheads , like rockerarms and bridge , valves and such items.Best regards Ubbe.
I have a set of Isky mechanical/adjustable rockers, as well as a pair of banana grooved shafts for the W2 setup. The only things I don't have are the bolts & spacers forthe rocker arms & shafts. PM me & we can discuss it.
Thanks for this info. very useful , Ubbe.The heads come up here on FABO pretty often.
Rocker arms come from Jesel, T&D, Harland Sharp, Crane, MoPar Performance and every now and then you can find some Norris Stainless steel rockers.
You can use a .150 long Chevy valve if you double check and correct the geometry. Springs are one of the few things that are relatively universal.
Intakes are MP and Holley. I'd love to have my Holley W-2 tunnel ram back. You can find them used on here and on eBay. You will also need headers.
