W2 Heads Rocker Arms
340arrow
Blue Springs, MO
Does anyone know if the rockers for the Econo heads will work on the race heads if you use the rocker stands for the race heads?
I think Econo heads use std rockers. I may be wrong there but IIRC the Race heads need the offset intake, the Econos dont. One of the reasons they are econo.
yes...rockers will work...but make sure the shafts are for the race heads
70aarcuda is correct. The rockers are the same. The shafts are offset drilled on the race heads which is why the stands are milled off. I think the long valve econo heads use a cast in stand that is repositioned to use a standard center drilled shaft but the rockers are all the same for any of the W2 heads.
The exhaust rockers are the same as standard head rockers the only difference is the left and right offset intake rockers.
