LOL BenYa'll go ahead and make fun of my work... I don't care... I spent a lot less than you did!!!!
Even a car guy would have a "WTH just happened" moment! hahaI want to be there when they hit they drop it in gear and it sucks the gauges through the dash and firewall.
# 4 is absolute genius!Ok, here's some of the pics I have saved from here.
1. Washers used to space out a shallower drum (ended up locking up the wheel on his way home)
2. The drum that was spaced compared to the original.
3.A custom X pipe. WTF?
4. A custom spring location bracket. (yea, that's a piece of pipe welded to a 1 inch strap AND they cut the frame out so the car wouldn't sit too high)
I really hope this guy is joking. Over the years who's ran into awesomely terrible stuff like this? Lets see it, or hear about it at least.
Well, if you look closely you will see his wire was made in Australia. That's why he has the zipties upsidedown!
I appreciate it. Let me save up some cash first..I could do that same exact job for you when you are ready.
Probably only charge you 4-500 hundred.
500 hundred??I could do that same exact job for you when you are ready.
Only way to make #4 worse and more impressive would be if if was an old wrench welded on as the strapping and a big socket for the spring bolt eye. Now THAT would be professional level hackery.[/QUOTE]
Nice! lolDon't underestimate the strength of 1970's coat hangers.
The transmission mount crossmember on my 66 olds 98 with a 425 rusted out at the rubber isolator frame mount.
All I had was a coat hanger and after securing one end, I actually used it to pull the weight of the engine and trans up to where I could wrap it around a few times.
Drove it home and to school/shop the next day.
Ended up tapping the frame and using C channel sections to make a rigid repair.
