WANTED – 1/25 Scale Long Tube Headers
pntastar69
Gilbertsville, PA
Looking for a set of headers for my Dart project w/a 440 from the Monogram Superbird kit. Looked thru my stash and found nothing that works. If you have an extra set that you’re not using or can recommend a kit with a nice set of headers, shoot me a pm.
Thanks,
Hope you're not too picky about the brand. I wound up using BBC headers on my '67 Coronet R/T replica I'm building. Using the Drag-On Lady kit with a 440 from a Dart. Nothing Mopar that I had would fit. It's probably going to be tighter in the Dart. I'm also building a '67 GTX replica from the S&M kit with a 440. Fortunately that car was bone-stock when I owned it so stock manifolds fit fine.
They were from the AMT '67 Chevelle Pro Street kit. I used the engine in a '55 I'm building. They were tight but worked in the Coronet. Even the Hemi headers that came in the Coronet kit wouldn't work with the 440. I tried headers from various kits- from the Color Me Gone '64 Dodge to a '70 SuperBee.
How about fabbing them from the sprue? Bend and strerch them up over a heat gun. I wish it were that easy for our 1:1 metal cars.....
I have some crappie amt general Lee hemi headers. That being said the 68 hemi dart has a good set in it alone with the Revell daytona charger 2 in 1 .not the amt daytona it's the same as the general Lee with a wing it's a bad kit for detail.
I used to make headers out of soldering wire all the time
Easy to work with and already has the right finish
The collector is the only tricky part, but I would just file or grind the runners down, grab a proper size piece of styrene and heatshrink it together
(very similar to this guy, except he doesnt put the reducers in i used to)
Making Headers
Thanks for all of the replies guyz. Gonna either buy a suitable kit and rob the headers or make my own out of solder.
Diymirage - The link for making headers out of solder is awesome. I looked on the net for something similar but couldn't find anything.
Making Headers
That's purdy badass man. If only real ones were that easy to make. lol
the fabo of model building is right here : Tips, Tricks, and Tutorials - Model Cars Magazine Forum
here is one similar, but with copper
Building exhaust headers from copper - Tips, Tricks, and Tutorials - Model Cars Magazine Forum
Not sure for your particular application, but the headers from a Revell '68 Firebird (400) seem to fit a lot of engine/chassis combinations. And they have the correct port spacing for big/small block Mopars.
I have that kit (for another replica build) but didn't look in it for headers. It will be a stock build and won't need headers. Thanks for the tip. :thumbsup:
