[WANTED] Wanted Low Deck Pushrods
d55dave
Kelowna, British Columbia
I am looking for a good set of pushrods to use with a solid lifter flat tappet cam in a low deck block with crane adjustable iron rocker arms.
If you have anything decent at a good price and are willing to ship to Canada let me know!
Thanks.
I have 40 sets of pushrods in the shop
most of which are new in the box.
How much has the deck been cut and
have the heads been milled. Plus how thick
is the head gasket?
If you have not found any before Thankgiving
I will jig up a block and try to see if I have the
correct size.
They will be no more than 1/2 Price.
If the pushrod are too short or long
you will have major Valve Train issues
as the rockers will not oil very well if at all!
I would recommend using an adjustable pushrod to determine the proper length before you purchase them. 65'
Yes, I agree. At this point the block is at the machine shop and I am gathering parts. With the adjustable rockers a I will have a small amount of wiggle room in rod length. I was wondering if anyone had a set for a standard deck height, standard head configuration, solid flat tappet and old school crane adjustable iron rockers configuration.
I am just in the parts gathering process, and if a set came up I might be interested.
Cheers,
