chucksrodgarage
old school rodder
still looking for a neutral pushbutton and rod (one piece). for a 1962 dodge lancer. i am in the porcess of restoring the car, and the neutral button was missing. no, it isn't down inside the shifter box. from what i understand , the 1962 is by itself in this respect. valliant may work . see attatched thread. any leads appreciated.
Chuck
How do you remove the headlight and wiper knobs on a '62 Valiant? The Valiant instrument panel was somewhat redesigned from the 1960-61 version, for which the manual says to reach around behind the instrument panel to push a release on the headlight switch.
For the 1962 Plymouth Valiant, you stick a tiny screwdriver up into the (almost invisible) slot on the bottom of the knob, and that releases a spring clip and lets the knob slide off.
To remove the pushbutton gearshift assembly from the dashboard (which appears also to have changed from 1961): after removing the instrument panel escutcheon to gain access, pry apart the pushbuttons a little bit to find a couple of 3/8" hex huts back inside, on studs that face toward the rear of the car. Remove those hex nuts and the park lock knob from the park lever, and carefully maneuver the pushbutton assembly back, down and out of the dashboard.
Thanks to Pat
Chuck
Thanks to Pat
