Wanted: Pin-Type caliper adapters for 11-3/4 Rotors
GreenB
Raleigh, NC
Rating - 0%
0   0   0
I'm looking for a pair of pin-type caliper adapters for 11-3/4" rotors.
I added disc brakes to my '68 Charger using A-body spindles.
Please PM
Thanks!
John
John - I have a set of brakes from a 70 E-Body that have pins? Are these what you are looking for? Not sure if they are the size you are looking for. Tell me how to check and we can work out something if needed
Hi Caz, The first thing to check is the diameter of the rotor. If it's 11-3/4" in diameter we'll go from there.
IIRC, the '70 E-bodies came with the smaller 10.87" front disks.
Thanks.
The adapters would look like these.
The distance between the center of holes "A" and "B" is 3-1/2"
Sliders are a lot more common, the pin ones I got were on a '76 Charger Daytona. Haven't seen another set in quite awhile, mostly because when I see one of those mid-to-late '70's cush mobiles they are later year Cordobas, Magnums or a 300 (one time).
