Was in FelPro gasket kit????
Mojoe9955
NJ
This came in a bag in the gasket kit.
What is it?
Hmmm, always something.
I'm "rebuilding" my motor, so I clean the damper, add the red stuff ad press in the sleeve?
Do I need it?
Thanks
Do I need it?
Thanks
only if your balancer has a groove worn where the old seal ran for years.. if it's smooth emory it/clean it up and run it..
Didn't realize i wrote converter... i have my transmission on my mind today :)
I've got some mystery gaskets too - my kit came with what looks like stamped steel intake gaskets - maybe for cast iron intakes - as a bonus I got three of them in the kit.
There's also some unknown round thick gasket kind of shaped like a donut
Is it a felt washer type thing? If so that goes over the crank snout after you get the timing cover on and befor the balancer. I believe it is to keep grit and dirt from getting to the seal
