Colohusker
Went to finish up the engine in the 70 Duster, putting the fan on and I don't have enough clearance. Was wondering if there is a shorter necked water pump than the one I have, or a shorter viscous fan clutch or a thinner radiator. Here are the measurements I have.
The space I have between the timing cover and the radiator is 9.25"
The distance between the water pump mounting surface and the pulley mounting surface is 6"
The distance between the fan clutch mounting surface and the face of the clutch is 3.25"
The radiator is 3" thick at the top cap, but the cooling elements are only 1.5" thick, but mounted flush to the inside of the top cap.
Any help would be appreciated!
Setup is a 1974 318 with a 904 behind it and I'm pretty sure the engine is in the right position since the 904 cross member slipped right into place.
