'64 Cuda
Anybody ever heard of or done any business with these guys? I was just searching for a water pump & came across them. They have a few pumps listed for small blocks & I was wondering if anyone had ever used their stuff. Their prices were reasonable.
http://www.waterpumpwarehouse.com/servlet/StoreFront
I sent a note to their tech dept asking for some specific info on their pumps to fit 69 & earlier smalblocks. According to them, the performance pumps...
Reduce cruising temps up 40 degrees
Have 2 times more pressure
Have 41% more flow
Are Up to 5 times stronger
Use new OEM quality castings, precision bearings and ceramic seals
Have a Lifetime Guarantee
It's probably typical hype but I'm interested to see what they say if they respond. They had a high performance pump to fit the early smallblock configuration (with the inlet on the left) for under $70 & the only comparable pump I know of is the Flowkooler 1701 & it's over $100 from Summit.
Have 41% more flow
