I can't remember if I "scaled" it, but when I went from a 7.25 rear to the 8.75 rear (9" to 10.25), the drum weight was definitely noticeable by feel/hand. Seemed like about a pound or more each.Anybody know the difference in weight between a 9" drum spindle and a 10" drum spindle? Thinking of switching my front brake setup, but it requires a 10" drum spindle.
Thanks. I am.Unless you are in super competitive, heads up racing, it's irrelevant.
wilwood race brakes are very light weight and call for a 9 inch drum brake spindle. Strange race brakes call for a 73 up disc brake spindle. Much heavier spindle but stronger for landing.Anybody know the difference in weight between a 9" drum spindle and a 10" drum spindle? Thinking of switching my front brake setup, but it requires a 10" drum spindle.
Are they that weak? I can't say i've ever seen a spindle break. I ran them for years, on the street, on my big block car.Your taking your life in your hands with stupid weak *** 9” drum spindles. I wouldn’t run them on a stock street car.
I would sacrifice the weight for the additional strength of the 10" parts.Unless you are in super competitive, heads up racing, it's irrelevant
He is using it in a race only application, which definitely changes things.
Is there enough meat to drill out the holes in the lower ball joint to 5/8?
So as not to derail this thread, I would love to see a separate thread on this car. I've got a '67 body shell I'm wanting to start this type of operation on.On the valiant we went with a straight axle. Now that was a true weight reduction.
Shouldn't be long , We just moved the machine shop to a new location. The valiant is in the big building resting next to the Dump truck , excavator and heavy equipment. He is trying to get caught up on engine work to pay some bills.So as not to derail this thread, I would love to see a separate thread on this car. I've got a '67 body shell I'm wanting to start this type of operation on.
