Weight Removal Thread
Mopar General Discussions
  1. SpeedThrills
    SpeedThrills FABO Gold Member FABO Gold Member
    1,756
    460
    Jun 3, 2008
    Very South Jersey
    Local Time:
    3:52 AM
    Anyone know if there's an existing thread where I could list the weights of some things I've replaced?
    Searched, couldn't find one.
  2. abdywgn
    abdywgn dismantler
    1,498
    748
    Jul 30, 2006
    Darien, Illinois
    Local Time:
    2:52 AM
    I'll be watching yours!
  3. '63GT
    '63GT Well-Known Member
    1,482
    1525
    Jun 9, 2018
    Turlock, CA.
    Local Time:
    12:52 AM
    ahh, looks like you just did :)
    List your weights, I'd like to see what you came up with...
  4. Treblig
    Treblig Well-Known Member
    6,381
    3540
    Oct 5, 2013
    South Texas
    Local Time:
    2:52 AM
    I took the lead weights off my wheels hoping to go a little faster but the car shook so bad I had to put them back on.........:realcrazy::BangHead::rofl:
    • Like Like x 3
    • SpeedThrills
      1,756
      460
      Jun 3, 2008
      Very South Jersey
      Local Time:
      3:52 AM
      Okay, here goes:
      (These are all from a 74 Dart Sport, except as noted)
      -Front bumper w/ all brackets, crash absorbers and hardware 62
      -Rear bumper, all stuff, as above 82
      -Fenders, including headlight buckets 22 ea
      -Hood (no hinges, etc.) 61
      -Hood hinges, latch, hardware 10
      -Door (Driver w/ mirror, no hinges, otherwise complete
      with glass, regulator, etc.) has crash beam 84
      -1972 Duster door, as above, no crash beam
      (first year for crash beam-1973?) 73
      -10" front drum brakes, everythng required (I swapped
      to Wilwood, they're 39#) 80
      I now have race weight fenders, hood, bumpers and Lingenfelter aluminum bumper brackets.
      The seats and heater box are gone, I wish I had weighed them.
      Everything was weighed on a beam type bathroom scale.
      Who has weighed what? List it!
    • SpeedThrills
      1,756
      460
      Jun 3, 2008
      Very South Jersey
      Local Time:
      3:52 AM
      You should get aluminum weights.
      :lol:
      • Like Like x 1
      • Northern Grit
        Northern Grit Well-Known Member
        156
        199
        Jul 21, 2020
        Michigan
        Local Time:
        3:52 AM
        75 a body;
        Dash pad. 3.65lbs
        Sun visors. 1lbs each
        Headliner, bows, attaching hardware. 4.76lbs
        Rear bench bottom. 20lbs
        Rear bench back. 16lbs
        Door seals (body side) 1.5lbs combined
        Steering wheel. 4.1 lbs
        4dr ft. Window regulator (no handle) 2.95lbs
        4dr rear window regulator ( "") 2.25 lbs
      • 70aarcuda
        70aarcuda Master Hoader of SBM FABO Gold Member
        15,751
        4284
        Jan 16, 2005
        las vegas
        Local Time:
        12:52 AM
        Here is my 75 Duster....
        got the bathroom scale out in the garage....
        Stock front disc brakes...... 78 lbs
        Stock rear drum brakes 54 lbs
        Total 132 lbs
        Strange Front Disc Brakes.......,,,32 lbs
        Strange Rear Disc Brakes 30 lbs
        Total 62 lbs
        Weight saving 70 lbs plus alot rotating weight
        stock Front bumper 65 lbs
        Bumper Shocks 21 lbs
        Fiberglass bumper and aluminum brackets 4 lbs
        Weight Savings 82 bs
        Total weight saving so far...........152 lbs.....
        • Like Like x 1
        • 70aarcuda
          15,751
          4284
          Jan 16, 2005
          las vegas
          Local Time:
          12:52 AM
          then I removed more...
          Hood... 40 lbs........
          I did not include the weight of the hinges or hook locking crap...
          weight saving on the rear bumper 80 lbs
          Another 120 lbs total..
          So over all the car should be lighten up over 270 lbs.....
          added a few pounds with the side bars for the roll bar....
        • pishta
          pishta I know I'm right....
          18,341
          7840
          Oct 13, 2004
          Tustin, CA
          Local Time:
          12:52 AM
          The bucket seats on my 65 Barracuda must have weighed 80 lbs a piece! I lifted one out and had to lift it back over the edge of the trunk and I think I pulled something.....
          • Agree Agree x 2
          • Treblig
            6,381
            3540
            Oct 5, 2013
            South Texas
            Local Time:
            2:52 AM
            Great idea!!! So how much weight would I save if I replaced 2 lbs of lead weights with 2 lbs of aluminum weights???
            • Like Like x 1
            • '63GT
              1,482
              1525
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              12:52 AM
              Love those brakes ! I have them too. Truly LIGHT !
            • oldkimmer
              oldkimmer FABO Gold Member FABO Gold Member
              16,569
              4903
              Nov 11, 2006
              Kindersley, Saskatchewan,
              Local Time:
              2:52 AM
              I have a 74 duster that has some lighter parts on it. I got the body with the interior already out of it. The hood bracing is taken out. Trunk lid is fibreglass as well as the front fenders. The 5 mph bumpers and shocks are replaced with 71 valiant parts. All stock type front end. Dana 60 rear. 470 stroker with alum heads and intake. Has a 14 point mild steel cage. 3100 lbs. Kim
            • '63GT
              1,482
              1525
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              12:52 AM
              How much did those steel fenders weigh (inner fenders too, I"m sure)? You recall ?
            • oldkimmer
              16,569
              4903
              Nov 11, 2006
              Local Time:
              2:52 AM
              Fiberglass fenders were not very much lighter. Maybe 5 lbs. Inner fenders we’re already out so no idea there. I haven’t did it yet but the side glass and window hardware are very heavy. They weigh more than the door. I want to do lexan. Kim
            • 70aarcuda
              15,751
              4284
              Jan 16, 2005
              las vegas
              Local Time:
              12:52 AM
              the car rolls some much easier with the strange brake...a lot less drag....
            • 65 Cuda 340
              65 Cuda 340 FABO Gold Member FABO Gold Member
              211
              231
              Dec 27, 2019
              Tallahassee Florida
              Local Time:
              3:52 AM
              65 Barracuda fold down rear seat: 70 lbs.
              73 Duster 340 bumper inside crash beams plus bumper guards: somewhere between 45 and 50 pounds
              67 Barracuda power steering gearbox and pump: 39 pounds heavier than a manual box.
            • 12many
              12many If I Only Had The Cash.......
              1,301
              1611
              Dec 14, 2016
              South Carolina, Thank God
              Local Time:
              2:52 AM
              Factory starter for Dakota version: 15 lbs vs. 8 lbs. (-7 lbs) Group 24 lead-acid battery for lithium: 40 lbs vs. 5 lbs. (-35 lbs). Factory glass for lexan: (same thickness) 3/16” side glass, 1/4” windshields = 50% less weight Factory 3/4” front sway bar with links etc: -10 lbs I’ve removed approx 300 lbs total from my van, the items above are about the only things that are relatable to a-body’s though
            • '63GT
              1,482
              1525
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              12:52 AM
              Do you know if it was worth any ET, MPH? I don't have a A/B comparison...
              A spool gets some serious weight out too. like 10# or so
