Would it be possible to post a pic or 2 of the front of the machine .
You’re going to need a retrofit kit to run the spool gun. I’ll see if I can find out which one you need and which spool gun will work.Ok .... I finally actually looked at my welder, there's a sticker but where the toggle switch would be but a plastic dummy plug in the hole for the toggle switch to switch operation from spool to mig.
I forgot what the sticker on front says (i just looked at it) . What does the toggle switch do? I mean I have to disconnect the wire feeder which is hooked to "+" polarity and replace it with the cable from the spool gun anyway.
The spool gun has a 4 pin plug, I didn't disconnect the plug from my mig gun yet to see if it's the same though it looks to be same diameter as the plug on the spool gun. I'm gonna have to get a small tank of argon anyway. I acquired one years ago (I forgot where) and at the time donated it to the career center welding Dept.
There is a second hole under the small gauge (looks like telephone wire) with nothing in the hole on the face of the welder. Maybe I misunderstood and I do need a kit? I took it as mine being "spool gun ready"
I did go to Miller website and put my serial number in and downloaded that manual
It says nothing about a spool gun at all.
Seems like the one that came with it did but I haven't seen that copy in about 5 years now. I have it somewhere.
BTW my machine is serial number KH 553093
And jeez I need to get the air hose and blow that thing out ....
maybe this weekend.Would it be possible to post a pic or 2 of the front of the machine .
