I can appreciate the DOHC heads. With a Hemi shaped chamber you can fill it up with 4 small valves. Something you can't do with 2 big valves in a small chamber.I should have a 2.055 head on the bench today with the 4.120 gasket chamber size and I’m betting I have flow numbers that are the same and a much smoother flowing head. Updates posted later.
340/360, EasyI have heard of 2.05 Intake valves for SBM heads, but never 2.08. Do they even fit?
Yes, W2s come with 2.08.
Okay, thanks!! I guess I’m used to seeing so many of them outfitted for 2.08 valves I just started assuming (I know, the MF’er of all F’ ups ) that they came that way…No, 2.02 as delivered
340/360, Easy
What kind of power does the customer expect? Over 600HP? The heads are capable of that I'm sure youre aware. J.RobHe had to get it bored to 4.060 so I’m not sure who’s recommending that gasket size (4.080) but it is what it is.
Prayers sent for a great outcomeGuys I didn’t forget about updating this post. My brother in law was supposed to get operated on Tuesday to repair a damaged heart valve but they found a huge clot in his heart so the operation is delayed till Tuesday. Trying to help my sister from afar. His heart is working at 2% and he’s been waiting 6-8 weeks for this operation.
Ask Dan!!!!A lot of things go into running that bigger valve. I gotta learn to ask more questions before I start a job. I about guarantee you this set of 2.055 valve heads will do better but even on these I’m limited to a 4.120 gasket size. So we shall see
Ask Dan!!!!
Bigger not necessarily better.And here I always thought a bigger valve would be a good thing!
