What are these 2 connectors for?
standup303
Colorado
74 Dart Swinger Slant 6/904. The single wire on the left is brown with a white stripe. It goes back to the top right of the far right harness.
can’t trace the right connector with 2 wires.
Can anyone tell me what they are for?
Had to kind of chuckle.
They are the No Start No Seat Belt circuit.
Have eliminated those in the past.
Yep, ^^^ 1974
Haha awesome. For a second there I thought they may be for something important. Thanks!
Yep, ^^^ 1974
I think "we" are looking at the wrong connector. The one he has circled is not the seat belt. The seat belt box is at far top right and is connected. OP--you need to take that connector off the seat belt reset box, and permanently jumper the two yellow wires in that connector
So far as the others, do you have a 74 service manual. If not send me a PM and I can get you one, for the cost of mailing a usb memory stick.
So far as the brown/ yel not sure. I found reference to a diode in the seat belt crap connected with maybe the back up lamp switch. (B3-20-BR/Y)
What color wires are in the connector with two wires coming out?
Maybe disconnect battery ground, hook ohmeter to the unknown connector, and random probe the bulkhead connector for a/ some hits
The single brown stripped wire to the multi-connector.
Could that be cavity D - wire V10 ? For the electric washer pump.
I didn't think it was long enough, but the thought occurred
