G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Feb 27, 2013 #1 These two connectors are hanging just behind the alt. The car ran and drove without them hooked to anything. Wires are blue/purple. What are they for? Attachments IMG_0806.JPG 83.7 KB · Views: 218
4spdragtop FABO Gold Member FABO Gold Member Joined Aug 28, 2009 Messages 39,875 Reaction score 23,301 Location Ontario Parts Unknown Feb 27, 2013 #2 Year/make?? Im assuming they could be for the horn relay?? Where do the wires lead to?
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Feb 27, 2013 #3 Geez sorry! 1972 Scamp /6. Not horn its hooked up and works. I need to look where they lead to but they are with the wire that goes to AC compressor.
ir3333 Well-Known Member Joined Jun 1, 2008 Messages 5,838 Reaction score 1,580 Location ontario,canada Feb 27, 2013 #4 purple is usually temperature sender... oops...looking at the wrong purple wire.
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Feb 27, 2013 #5 Temp sender also hooked up.
salinasjoel Learning Daily Joined Nov 17, 2011 Messages 1,198 Reaction score 39 Location Indianapolis, IN Feb 27, 2013 #6 Could it be to one of your hi beams? The wiring diagram on mymopar.com shows violets to the headlights
salinasjoel Learning Daily Joined Nov 17, 2011 Messages 1,198 Reaction score 39 Location Indianapolis, IN Feb 27, 2013 #7 Sorry that's violet with tracer
jos51700 Green Bearing thread connoisseur Joined May 24, 2009 Messages 7,458 Reaction score 3,142 Location Bel-Ray Feb 27, 2013 #8 Air conditioning (?)
straightlinespeed Sometimes I pretend to be normal Joined Oct 21, 2012 Messages 10,630 Reaction score 4,399 Location Uvita, Costa Rica Feb 27, 2013 #9 I 2nd A/C probably the high pressure switch on the Drier
str12-340 FABO Gold Member FABO Gold Member Joined Dec 26, 2012 Messages 4,420 Reaction score 4,071 Location Vashon, WA Feb 27, 2013 #10 on my 70 Dart w/ac the blue one goes to the AC clutch and the purple one goes to the temp sending unit. Maybe someone replaced some shorted wires and just left the old ones in place?
G green72 Well-Known Member Joined Aug 21, 2012 Messages 152 Reaction score 15 Location cedar rapids Iowa Feb 27, 2013 #11 The car does have A/C. I took it out, I don't remember unhooking these but that doesn't mean I didn't!! Thanks
replicaracer43 Grumpy Old Man Joined Oct 10, 2008 Messages 6,068 Reaction score 7,968 Feb 27, 2013 #12 Probally went to the pressure switch on the drier.....
BillGrissom Well-Known Member Joined May 10, 2009 Messages 8,131 Reaction score 1,047 Location Sacramento Feb 28, 2013 #13 Ditto. The compressor was on the other side.
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,481 Reaction score 13,904 Location Berlin,N.J. 08009 Feb 28, 2013 #14 a/c pressure switch fenderwell of the passenger side??
replicaracer43 Grumpy Old Man Joined Oct 10, 2008 Messages 6,068 Reaction score 7,968 Feb 28, 2013 #15 Like so.... Attachments PICT0215.jpg 95.1 KB · Views: 127 PICT0216.jpg 62.9 KB · Views: 120
abodyjoe Well-Known Member Joined May 22, 2004 Messages 24,481 Reaction score 13,904 Location Berlin,N.J. 08009 Feb 28, 2013 #16 Bingo
