Abbey Road, 180 Gram, remastered vinyl
Absolutely SUBLIME, as is Magical Mystery Tour & Black Sabbath vol 5... Im slowly rebuilding my vinyl collection that I wore out in my younger years. Its all being pumped thru a Technics mag drive SL-1200 Mk2 Turntable, connected to a Nakamichi CA-5 Preamp, tied to a Nakamichi PA 7 Mk ll Stasis firing out of a pair of Polk Audio Lsi-15s towers...
Im finally in Heaven
Q: Was it remastered all in analog? I'm finding that a lot of "remasters" sneak in digital processes... For a fact, the old MFSL Beatles Box Set was all analog.
MFSL is still doing stuff now, but it's not pure analog...
"The Beatles' masters were originally recorded using the EMI 'British Tape Recorder' ; after extensive tests, a Studer machine (bottom) was chosen for the digital transfers."
Its remastered from their 4 Track reel to reel tapes.....but Im sure they all have a bit of digital in there somewhere. cant get away from it
The newer ones for sure!
The Beatles-The Beatles Stereo Box Set-180 Gram Vinyl Record|Acoustic Sounds
Did you know that the Abby Road LP as the first Beatles recording to use solid state?
Earlier stuff was all tube equipment.
I've found all the remastered stuff is brighter and louder then the older stuff...almost everything on Tidal I find harsh to listen to.
I have a tube front end and it does nothing for that remastered stuff...it's just too bright for me.
Don't get me wrong, that amp is very cool, but I cannot hear the difference between inexpensive amplifiers and audiophile gear. If an analog signal is amplified and reproduced correctly, meaning identical waveform and nearly no distortion or noise, then it's the same no matter how much the gear costs or if you use tubes or semiconductors. Warmth, coloring, tube-like sound is really a form of distortion.
