What B engine cylinder is leanest?
MidTexCuda
Ancient Member
Deep in the heart of Texas
Finishing my headers for my boosted 512 and will be running a two sensor wideband. What cylinders are typically the leanest or should i just stick one in each collector?
What intake manifold? On single plane manifolds the sequential firing of #6,#5 and #7 can deplete the cloud for #7 in some rpm ranges.
Run one in each side and read your plugs. You can also weld a bung in each primary and move the O2 sensors around.
Ya that was kind of the response I was expecting. I knew my options just didn't know if there was a simple answer like "oh #5 and #6 are always the leanest"
The intake is a Indy single plane.
