I'll just list ALL the bearings that I find on summit under Dodge/360/LA.
Obviously not too much confusion with rod bearings being summit only lists sealed power. I'm having a hard time deciding between brand/material/price for cam/mains. The only area I can really save a buck is cam bearings. Is it worth it to run cheaper bearing for the cam(dura bond), or should I just run all sealed power to be safe? Isn't sealed power made by Federal? I'm a rockie, the only brands I was familiar with was Federal modul and Clevite. I'm not familiar with Dura bond, sealed power, speed pro, king, ect. Why does summit not list Federal?
Heres all the materials? Anyone care to elaborate on these?
Bi metal, chill cast
Bi metal, lead-based
Bi metal, fluoropolymer lead-based
Bi metal, alecular alloy
Bi metal aluminum alloy
Tri metal copper-lead alloy
Tri metal, TM-77
B-1
B100
Tin based
Alecular silicon
Steel backed
Heres what summit lists for bearings....
Cam:
Dura-Bond:
PD-16: Direct replacement: Bi metal, lead-based micro babbit ($15.95)
PD-25: Direct replacement: Bi metal, lead-based micro babbit ($19.95)
PDP-16: Performance: Bi metal, chill cast micro babbit ($32.95)
PDP-25: Performance: Bi metal, chill cast micro babbit ($45.99)
PDP-16T: Performance: Bi metal, fluoropolymer lead-based micro babbit ($63.95)
Clevite:
SH1112S: Direct replacement: B-1 ($31.95)
SH875S: Direct replacement: Steel backed micro babbit, B-1 ($37.95)
King:
CS527BB: Direct replacement: Bi metal, lead-based micro babbit: ($35.95)
CS512BB: Direct replacement: Bi metal, lead-based micro babbit: ($38.95)
CS512HP: Performance: Bi metal, chill cast micro babbit: ($82.95)
Sealed Power:
Z1484M: Direct replacement: Tin based babbit, B100: ($29.95)
Z1451M: Direct replacement: Tin based babbit, B100: ($36.95)
Rod:
Sealed Power: chamfered stock size
Z87125CH: Performance: Tri metal copper-lead alloy: ($75.99)
Main:
Clevite: 1/2 stock size
MS1051P: Direct Replacement: Tri metal, TM-77: ($81.95)
King: 1/2 stock size
MB517SI: Direct Replacement: Alecular silicon: ($62.95)
MB510AM: Performance: Bi metal, alecular alloy: ($79.95)
Sealed Power: 1/2 stock size
Z4999MA: Performance: Bi metal aluminum alloy, A-Series: ($59.95)
Sealed power: 3/4 stock size
Z4948MA: Performance: Bi metal aluminum alloy, A-Series: ($69.95)
Z4948MA: Performance: Bi metal aluminum alloy, A-Series: ($71.95)
Speed Pro: 3/4 stock size
Z120M: Performance: Tri metal copper-lead alloy: ($71.99)
