So I'm confused about a little detail here. It's a 10:1 motor, aftermarket cam, a few other goodies, but he ditched the factory adjustable rockers for later model stamped? and on an aftermarket cam at that? Did he use custom cut pushrods?
What heads does your car have? (I didn't see it listed in any of the posts).
I ask because I JUST got done going through all this and installing 273 rockers on my 360 to get the adjustability with my cam.
Use this calculator to find your gear ratio:
http://www.thedirtforum.com/gearratiocalc.htm
Go for a spin, note what speed you are going in 4th gear, and what RPMs you are turning. This is for 1:1 automatics, so divide the gear ratio it gives you by the final drive ratio for your 4spd (stock 833?).
