toddlaine
1972 Dart Swinger ,318, Edelbrock Performer Intake, Edelbrock 650 Carb, 340 Stock Exhaust Manifold, Stock Heads, What Cam should I get? Thanks,:cheers:
I use this one in a very similar engine with their recommended springs, retainers and locks. http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=625&sb=2
Be careful with lift as stock 318 heads wont take much more than .450" depending on seal used.
http://www.summitracing.com/parts/LUN-60401/[/URL]
What's your budget?
This if you're on a tight budget: http://www.summitracing.com/parts/SUM-6900/
This if you can spend more: http://www.summitracing.com/parts/LUN-60401/
If I go with the summit I can then afford the springs and a degree kit. Is the Lun worth tha added expense?
In order to change the springs do the heads need to be removed?
