My sons 73 Duster has a 9 bolt 7 1/4 rearend with 5 on 4 bolt pattern. We are using a set of 1 inch thick adapter plates to convert to 5 on 4 1/2 to fit the wheels we put on and match the disc brake fronts we converted too. The rear wheels rub in semi hard corners and the bearings will need to be replaced soon. We will be swapping out the slant 6 for a v-8 some day soon so I will be looking for an affordable rear to swap in. Besides the valiant what other cars have the same rearend that we can target for a direct swap?
Thanks Jerry
Thanks Jerry
