Hoping someone can identify this center link. It is different than what's currently on my 68 Barracuda. In the process of factory disk brake upgrade. Wanted to know if it was useful. Part number is 3402797. Thanks
Is that swap necessary if adopting 73+ factory disc brakes?It looks like a 73 to 76 center link. Won’t be compatible with your steering setup on your 68 unless you swap all steering components from the 73+.
No.Is that swap necessary if adopting 73+ factory disc brakes?
If your changing these parts anyhow I would go 73 up so all your front suspension components are for the same year excluding Strut bars and sway bar. JMODue to fact swapping to 73+ factory disc then why not steering assembly as well since I need new steering and idler arms. Is one better than the other?
Thanks. Think I just found one at Bergman. Appreciate the reply.I just installed one for 68-72 . They have them.
