Larry Hutchens
Active Member
Clean gunk type stuff with denatured alcohol that you can get at any hardware store. For rust I would use Evapo-rust, won't damage the metal. Be careful and check the cylinder bore for pitting. Brake fluid tends to absorb moisture from the atmosphere so damage is likely.
