What clutch are you using on your early 273
The ram clutch we got said good for 500hp and it was the puck type worked really well car went 13.80 spinning out of the hole.
There is no good clutch for the 122 tooth flywheel. With a 273 I would suggest that you upgrade to 130 tooth flywheel, clutch and bellhousing.
The 10" clutch from Brewer's is not performance oriented. I know, because I asked them. The .org site is trying to do a group buy for a new design from Ram. You may want to check it out.
