Kevindc
I'm working on putting together the ignition system for my 525hp 407 and have been trying to figure out the best way to go. The motor already has the MSD 8388 installed and timing set by the engine builder/Dyno. The MSD literature is not providing much guidance.
So I need a coil but what can or should I use. I know that a canister type will work but what about others? A ignition control can be used but is not needed. Should I use the ignition control or is it a waste of money. Thanks all.
