tiltedsix
hello out there...I picked up a 4 barrel manifold & carb for my 225 slant six...in a 1973 Scamp...what else do I need to change......thank you for your time
Or put a block-off plate over the heat riser port on the exhaust manifold.Is it a Clifford or Offy? If a Clifford you'll need to run headers as it won't bolt to a stock exhaust manifold.
