65TerrorCuda
I found my shifter cable wasn't adjusted right on a hurst v-matic attached to my 904. It was off three whole turns on the morse cable end at the trans, so that when I had it in "D" it was partially selecting 2nd.
Fluid is red and clear, smells normal. My vacuum has gone up 2-3" cruising since fixing this, I'm wondering what the hell I did to screw this up 25 years ago. Shifts completely differently too, much better and like it should
Also, there used to be smoke that I thought was blowby coming from the hood but that's disappeared. Man I must've been laying in the dirt getting bit by fire ants while adjusting the shift cable with a chicken nugget to goof up this hard.
Here's how far off it was before. I just popped the barrel out of the arm and snapped this pic:
